Hi waiyeenyeang,
If you are performing a harmonic response analysis, the real solution is at phase 0 degrees while imaginary is at 90 degrees. You can export the nodal results at the scoped surface by right-clicking on the result and using the Export functionality. The same can be done for velocity to export the complex values.
Sheldon
