Rahul Mule
  - wta errors often occur when a case file of a recent FLUENT version is to be loaded into an older one
 - it also occur if (in the Workbench) an incompatible network is to be loaded to a set-file
Please check which cause is likely to occur to you.
Hope that helps you !!
Rahul
