Kyle
When you use the 3D index monitor, what is the "z" position of the plot you're showing? The 3D index monitor will record data at a range of z positions, when you open it in the visualizer you have to select the z position:
I would recommend using the index monitor to verify that the geometry is being exported/imported properly first before trying anything else.
