Guilin Sun
yes. The rule of thurm is, for uniform volume it only needs coarse, larger edge length whereas for small dimension, large gradient of doping or static fields smaller edge length is needed. The meshing begins from large edge length and then refines it by those constraints, until the iteration limit is reached.
