We can export the solid surface position (stl option in the Design Tool panel)
To get the solid skin. You'll then need to create a solid mesh. It's also possible to export the temperature for the domain, but you may need to trim that to suit the Mechanical model. Then you need to update this every some time steps as the solid grows and cools to find the stressy stuff in Mechanical. So, in theory it's possible, but as a Fluids specialist I'm not sure how. Steve might have some ideas from the FSI side of the solvers.
