Sean Harvey
Hello Sidrah,
There are 2 possibilities, maybe you are using an older version of Sherlock such as  2020 R1 or earlier which it uses Sherlock’s legacy mesh. If not can you change the mesh size slightly and that can help fix the issue.
Thank you!
Sean
