OK, you don't have a particle velocity profile as such, you have point data as a particle (stream) passes through a plane. However, if you turn on the Contour plot option Fluent will average some of the DPM values into the cells. Depending on how many particle steams you have this may produce a "spotty" contour, post what you see for comment.
