George Karnos
Thank You for trying that.
What I would like to see is the environment settings, and this is what this does.
But, not everything is listed in the window you screen-shotted.
Can you type the following in the DOS Command prompt window:
set >set.txt
This will create a file named set.txt in the directory where the DOS cmd prompt opens to.
When this is finished, open the file set.txt with notepad.
copy all contents and paste in a post
Thank You.
