sahua1
Hi, Thanks for the feedback. Yes, the material property is critical. I should check that.
Regarding the scripting. I checked the document you mentioned. the examples shown are mostly to set the parameters or to extract data from results.
Is there any demo scripting for changing the AC loss factor frequency dependent? Or something similar I can use.
Ashish Sahu
