Navya C
Hi D_D ,
Which Ansys tool are you using?
If you are using Ansys Maxwell, you can calculate the force experienced by the magnet by assigning the force parameter to the magnet.
You can look at the Below help section to understand how to set up a transient problem.
If this did not solve your problem, explain How is your simulation setup and what results do you get with the help of some screenshots. This will help interpret the problem correctly.
Navya
