Navya C
Hi junaed.buet,
The case you explained will not happen generally.
But from the information, you provided below are the observations and suggestions.
1) Looks like there are some global variables($Lend...) defined. Please check if any time-dependent parameters are defined for them.
2) Is the speed constant or is there any variable affecting the speed?
Navya
