SaiD
You may find this blog post helpful: https://www.padtinc.com/2022/02/03/hold-my-beer-spatially-varying-materials-in-ansys-mechanical-made-easy/
You could create an excel file (which is saved as .csv) that records the properties at varioud locations (may be a few point around the circumference and in the radial direction, and then use Import data option to map them as material properties.
Hope this helps!
Sai
