Ashish Khemka
Hi John,
I do not have the data for this material but I believe that this material is low-carbon steel. What is the analysis you are planning to perform? If it is a simple static linear analysis then Young's modulus and Poisson's ratio for steel should suffice. If you are planning to model plasticity/ failure as well then you may need the stress-strain data.
Ashish Khemka
