lgutt
Well, as I just said above I'm interested in the case where there is a perturbation introduced which results in a nonzero overlap. If you can find the overlap between modes with a perturbation included, then I will happily use the overlap tool. If not, I still hope you can answer whether it's possible to return mode profiles normalized to power instead of to 1.
