m.steppe
Hello Mr. Kanade,
thank you for your answer, so if i read the manual correctly, it is only possible to integrate the user parameters from inventor in plugin and pseudo-reader mode, which both requier Inventor to be installed on the same system. This is sadly not the case on my server, so i can't make the design-point-research via inventor parameters.
Kind regards
Milan
P.S. Sorry for my late answer
