jfonken
Using the *TREAD command, I'm able to import the Fluent pressure values into Mechanical APDL. However, this is only done before the first time step, but then no Fluent pressures are available yet. I would really appreciate any help to update the pressure table during the system coupling simulation. Which command(s) should I use to issue the *TREAD command (updating the pressure table) at every coupling step?
