Satyajeet Padhi
If you are using Classic Icepak, then go to Post->Variation plot to plot temperature vs. distance.
If you are using AEDT Icepak, then you need to create a polyline, then use Icepak->Results->Create field reports->Rectangular plots. In the panel, select the polyline as geometry and increase the number of points to get a smooth curve. Select temperature as quantity and click on New report to obtain temperature vs. distance.
