mohammedlaminemekhalfia
This message I got when I reduced the number of modes from 180 to 121 but for the first case it was mentionned a lake of files ( corrupted database ) for the  memory I am sure that I have sufficent alloacated memory (RAM) and storage capacity of hard disk.
PRINT CAMPBELL DIAGRAM
    Sorting : ON
    X axis unit : rd/s
    Driving component : CM_ROTVELCITY53
    Printout all frequencies
 *** FATAL ***                           CP =   14177.062   TIME= 16:52:51
 This model requires more scratch space than available.  The program has
 currently allocated 39439 MB and was not able to allocate enough
 additional memory in order to proceed.  Please increase the virtual
 memory on your system and/or increase the work space memory and rerun
 the program.  Problem terminated.
 ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= ansabort.db
  FOR POSSIBLE RESUME FROM THIS POINT
 The above error is non-recoverable by ANSYS
  ANSYS run terminated by the indicated error
  Current data base saved if possible.
