Erik Kostson
That has been noticed (apdl ui given issues).
I would therefor suggest to use it via input files/commands and not from the UI.
E.g., to define elements use ET command, etc. All fo the commands can be found in our command reference manual.
Also there are many input file examples in our help which can be used to learn the command/design language that APDL uses.
All the best
Erik
