Reno Genest
With the speed you can calculation displacement. Assuming a constant speed, you can calculate a displacement based on the time. For example, if you need a displacement of 10 mm in 1  second, then the constant speed will be 10 mm/s. You can then calculate the rotation speed  using the equation above.
