mohammedlaminemekhalfia
okey, also I have problem in launching the SYSTEM COUPLING GUI using the  Command line. I could not register the project in a Command line format as when exporting it does not give the adequate format to export under it which does not permit changing the number of process and this lead to a huge compuational time just for small problem like that.
I will try to perform it and return to you with updates
Thanks a lot
