al1419
Thank you!
I also have another issue with post-processing if you don't mind kindly looking at it. Whilst looking at the temperature distribution of this certain pipe, I've applied a 330 degree velocity inlet BC to the two pipes shaded in dark blue and a pressure-outlet at the end shaded in red. However the temperature distribution suggests the fluid's temperature increases? I don't think this makes sense. Is there something wrong with my initialization method? I used hybrid initialization and the velocity-in and pressure-out are the only BCs I used
