Praneeth
Yes you can get the format for a full stack up layer definition. Are you aware of recording script option provided in the Automation tab? You can use that option and open the edit layer option in the UI. Do the modifications as required and close the window. You can stop the script and open it to see how it is implemented. This script you can modify by simply running the updated script.
Best regards,
Praneeth.
