al1419
How comes there are 2 temperature values for inlet and outlet? And also, the thermal BC for the outer pipe wall is convective
(edit: apologies I've accidentally applied the report to only 1 outlet instead of all, I've assigned 1 outlet to the end of each fluid - will this be a problem? )
