a.acheampong
Hello Victor,
I have performed a similar analysis before where I used 182 csv files (i.e 182 seconds) to map onto my Static analysis simulation.
The mesh and the geometry must be in the same x,y,z coordinate system.
I used the external data as below
This is how csv time 155s looks like. You do the same for all files
Now back to the mechanical environment the analysis settings for both thermal and the static structural should be set to 182 steps
The imported data looks like this;
Use the same method for the static structural and make sure the time step is set to the same as thermal
You should get something similar to this
Hope this helps
