ejlee0911
Thanks for your help!
I have a question to use S parameter.
A generic approach you kindly mentioned is applied for metasurfaces in which the incident light was coming outside from them.
But I would like to check the results when the source is inside the structure. And is it still okay to define the metamaterial span and center?
