The model you have shows the permanent deformation with some rigid body motion. You could export the deformation of the sheet at the end of the simulation, obtain the directional Y deformation of one "pilot" node, and subtract that value from all nodes. The "pilot" node will always have a Y deformation of 0. In that way you can superimpose the offset nodal data to look at differences in permanent deformation between loads.
