Keyur Kanade
Please check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
Please split the faces at that location and then check different sizes at that location.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/tgd_user_workflow_guided_tasks_setup_mesh_controls.html?q=curvature%20sizing
If this does not help, split the geometry around that location and try to mesh only that small part to come up with correct sizing or solution.
Keyur
