DrAmine
That Window is not only for that field. We have a multi-purpose code. If you try to provide a profile for that field you cannot do that using UDF for example.
Can you tell me which correlation are you trying to follow or which formula you want to assess? Do you want to give temperature based conditional for the treatment?
The theory is mentioned in the documentation: you require surface temperature gradient.
