Rahul Mule
Hi Judith,
When a co-simulation coupling participant, such as a Fluent system, is connected to a Mechanical
system via System Coupling, Mechanical is given access to data directly from the other participant. So, I would suggest you to create conformal mesh and specify the velocity at the extended part and transfer data directly from Fluent to Mechanical through system coupling.
System Coupling (ansys.com)
