The case and data will be split over the number of cores in the new session, so assuming you do launch 72 cores you should see a message in the transcript about re-partitioning from 10 to 72.  Double check where any saved monitors are going, and also if you have UDFs these may need to be recompiled if moving from Win10 to LINUX.
