Mn65
Dear Sheldon,
Thank you very much for your reply.
Could you consider the following problem?
I have a question regarding the following problem that I'm trying to study in ANSYS Workbench. I'm simulating an adhesively bonded joint of a double cantilever beam  (DCB), and I'm trying to predict the load-displacement curve of this specimen. I did the following steps:
1- The experimental DCB tests were done and the load-displacement curves generated
2- The fracture toughness (G) of the adhesive was calculated with the analytical formulations
3- The same geometry was simulated in ANSYS Workbench (with the VCCT model) to create a FE model that could be able to predict the load-displacement curve of the experiment test (under the same loading conditions)
4- Then the FE model was modified by changing the mesh size and the value of G to reach the closest load-displacement curve to the experimental curve.
I have the following questions regarding this issue:
1- The following warning appears, what does it mean, and how I can solve it;
"The fracture parameters computed during solution may be incorrect. Check the Solver Output on the Solution Information object for possible causes"
2- Do you have any idea to improve my model to have a closer load-displacement curve with the experiment? The following image shows a comparison between FE and the experiment curve.
Thank you in advance for your consideration.
