It's the maximum number of iterations that can be solved for a time step. If you hit the limit without converging the time step there's a good chance the solution will not be accurate. Ideally, you want a time step such that you hit the convergence criterion in 10-ish iterations, but don't do less than 2-3 to ensure the solution is actually updating.
