HDLI
Hello Sherin Joseph,
       My suggestion is to use dataset to build PWM waveform excitation, as similar as your inputs, to test the Maxwell model.
       If your inputs is not correct in the Simplorer, please check the inverter with indutance and resistance load first. We need to seperate models to determine which part has an issue.
HDLI
