amora
I defined the parameters in the variable panel and still not able to draw the truncated cone. For the bottom radius, I gave it a variable 'rrr' and defined it in the variable panel. I also changed the units in line number 109 and 110 in the attached photo.
Also, in line 102, you can see that it has tti and tau. These two variables are defined in the panel and the script did not apply them
