Guilin Sun
Sorry, I did not see your variable table (panel) before.
In the variable table, you have already used um (micron meter) unit. So in the script file you do not need to multiply 1e-6 again.
Take the truncated cone from the FDTD object library as an example:
Please directly use it and modify the values of the variables.
