Khashayar Ghaffari
Can you share a screenshot of the Objects Tree wich shows the objects hierarchy ("model", solver, and the two mesh objects). As you suggested multiple mesh objects should be applied at the same time. This might be a software error specific to the objects hierarchy. Your update will be helpful in determining this. Also, what is the software version you are using? Thanks.
