Shoaib Shah
Hi
Automatic remeshing is not available through Workbench and hence the fail. You can only get these updates inside Fluent Icing or FENSAP-ICE stand alone products.
In version, 221, you should be able to run this. It depends on mesh, and trailing edge settings (separate zone), material point placement and zone naming. Kindly check the manual for details on 2.5D remeshing.
