Shoaib Shah
On the variable error, workbench and stand alone ice3d, if run by itself will not be able to set up the necessary variable.
In practice, we setup sequence type runs, (multishot_fluent or multifensap) when wanting automatic remeshing. This should fix the env variable problem. Thanks
