Yu Bi
Hi, I checked on my end, and the current data importing worked fine. To ensure we are on the same page, the function that went wrong on your PC is the highlighted part in the picture below, right?
The csv file I imported is shown in the picture below when I open it in the text editor (e.g. Notepad++):
The rules about this csv file are in our Aqwa User's Manual, Section 5.10.9 Current. If you still continue to see the problem you described, please raise a service request ticket in the customer portal if you can. That will allow you to send the problematic project and files to us to do a detailed investigation. Thanks.
