ll00023
kw-sst model is used. steady RANS case, 3D model, mesh has been validated.
First cold flow without particles is converged.
Then two type of particles are injected;  DPM iteration interval 1000 still does not work.
if just injecting coal particles, cold flow with particle will converge.
biomass particle's density is half of coal particle's density.
I will try to only inject biomass particles to test whether it converges.
converged cold flow without particle, as expected
diverged cold flow with two types of particles,
