Open SpaceClaim, File Save and name it 3layers.scdoc.  Create a New Component and name it Layer1. Sketch two circles and Pull the solid cylinder.
Activate the parent file called 3layers, create a New Component and name it Layer2. Sketch two circles and Pull the solid cylinder.
Activate the parent file called 3layers, create a New Component and name it Layer3. Sketch two circles and Pull the solid cylinder.
Activate the parent file called 3layers, click on the Workbench tab and click the Share button.
Now you have three solids that will share nodes at the two common surfaces. In Mechanical, each solid can be given a unique material.
