maria.marinari
This is the whole compilation message:
Working with C-Source file names: C:/Users/laouit0115/Desktop/VariableThrustTest/p(U,r)Devel/VariableThrust.c
Give header file names:
Copied C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\VariableThrust.c to libudf\src
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\sconstruct.udf "libudf\win64\3d_host\SConstruct" ")
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\scons_default.bat "libudf\win64\3d_host\scons_test.bat" ")
1 file(s) copied.
Files udf_names.c and user_nt.udf in 3d_host are up-to-date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\makefile_nt.udf "libudf\win64\3d_host\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3d_host")
C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_host>rem
C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_host>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
'cl.exe' is not recognized as an internal or external command,
operable program or batch file.
'clang-cl' is not recognized as an internal or external command,
scons: Reading SConscript files ...
Compiler used is "C:\PROGRA~1\ANSYSI~1\v212\fluent"\ntbin\clang\bin\clang-cl
Linker used is "C:\PROGRA~1\ANSYSI~1\v212\fluent"\ntbin\clang\bin\lld-link
Copy("C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_host\resolve.exe", "C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\win64\resolve.exe")
Copy("C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_host\VariableThrust.c", "C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\src\VariableThrust.c")
c_sources ['VariableThrust.c', 'udf_names.c']
c_sources_ ['VariableThrust.c']
scons: done reading SConscript files.
scons: Building targets ...
resolve.exe -udf VariableThrust.c -head_file ud_io1.h
"C:\PROGRA~1\ANSYSI~1\v212\fluent"\ntbin\clang\bin\clang-cl /c /DUDF_EXPORTING /DUDF_NT /DWIN64 /EHa /wd4224 -Wno-return-type -Wno-implicit-function-declaration -Wno-comment -Wno-incompatible-library-redeclaration -Wno-reserved-user-defined-literal /clang:-std=c99 -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\win64\3d_host -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\main -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\addon-wrapper -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\io -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\species -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\pbns -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\numerics -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\sphysics -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\storage -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\mphase -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\bc -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\models -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\material -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\amg -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\util -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\mesh -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\udf -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\ht -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\dx -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\turbulence -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\acoustics -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\parallel -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\etc -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\ue -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\dpm -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\dbns -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\cortex\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\client\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\tgrid\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\PRIME\tgrid\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\multiport\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\multiport\mpi_wrapper\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\include -I C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_host -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\MSVC\14.10.25017\include -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\x64\lib\clang\10.0.0\include -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\10\Include\10.0.18362.0\shared -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\10\Include\10.0.18362.0\ucrt -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\10\Include\10.0.18362.0\um VariableThrust.c
In file included from VariableThrust.c:4:
In file included from C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\udf\udf.h:22:
In file included from C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\main\global.h:258:
In file included from C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\storage\var.h:10:
C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\10\Include\10.0.18362.0\shared\basetsd.h(322,12): warning: cast to 'void * __ptr32' from smaller integer type 'unsigned long' [-Wint-to-void-pointer-cast]
return((void * POINTER_32) (unsigned long) (ULONG_PTR) p);
1 warning generated.
"C:\PROGRA~1\ANSYSI~1\v212\fluent"\ntbin\clang\bin\lld-link C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\win64\3d_host\fl2120.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\multiport\win64\net\shared\mport.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\libcmt.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\libcpmt.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\libvcruntime.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\oldnames.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\uuid.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\onecore.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\libucrt.lib /dll /out:libudf.dll VariableThrust.obj udf_names.obj
scons: done building targets.
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\sconstruct.udf "libudf\win64\3d_node\SConstruct" ")
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\scons_default.bat "libudf\win64\3d_node\scons_test.bat" ")
1 file(s) copied.
Files udf_names.c and user_nt.udf in 3d_node are up-to-date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\makefile_nt.udf "libudf\win64\3d_node\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3d_node")
C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_node>rem
C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_node>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
Copy("C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_node\resolve.exe", "C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\win64\resolve.exe")
Copy("C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_node\VariableThrust.c", "C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\src\VariableThrust.c")
"C:\PROGRA~1\ANSYSI~1\v212\fluent"\ntbin\clang\bin\clang-cl /c /DUDF_EXPORTING /DUDF_NT /DWIN64 /EHa /wd4224 -Wno-return-type -Wno-implicit-function-declaration -Wno-comment -Wno-incompatible-library-redeclaration -Wno-reserved-user-defined-literal /clang:-std=c99 -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\win64\3d_node -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\main -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\addon-wrapper -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\io -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\species -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\pbns -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\numerics -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\sphysics -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\storage -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\mphase -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\bc -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\models -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\material -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\amg -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\util -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\mesh -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\udf -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\ht -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\dx -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\turbulence -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\acoustics -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\parallel -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\etc -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\ue -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\dpm -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\dbns -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\cortex\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\client\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\tgrid\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\PRIME\tgrid\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\multiport\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\multiport\mpi_wrapper\src -I C:\PROGRA~1\ANSYSI~1\v212\fluent\include -I C:\Users\laouit0115\Desktop\VariableThrustTest\p(U,r)Devel\libudf\win64\3d_node -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\MSVC\14.10.25017\include -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\x64\lib\clang\10.0.0\include -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\10\Include\10.0.18362.0\shared -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\10\Include\10.0.18362.0\ucrt -I C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\10\Include\10.0.18362.0\um VariableThrust.c
"C:\PROGRA~1\ANSYSI~1\v212\fluent"\ntbin\clang\bin\lld-link C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\win64\3d_node\fl_mpi2120.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\multiport\win64\mpi\shared\mport.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\libcmt.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\libcpmt.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\libvcruntime.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\oldnames.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\onecore.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\libucrt.lib C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\clang\lib\uuid.lib /dll /out:libudf.dll VariableThrust.obj udf_names.obj
Done.
This is the whole UDF:
#include "udf.h"
#include "math.h"
#define R 89.15
    /* Defining the parameters of the equations */
    real  A[ND_ND],C[ND_ND],r, thrust, fit, Area;
void calc_Thrust(real* F, real* Thu, real Uin, real maxU, real U)
        real a, b, c, fit;
        if (U <= maxU) // this should be based on velocity at the disk
            a =        6547;
            b =       2.593;
            c =   2.565e+05;
            fit = 1;
        else
            a =   8.283e+06;
            b =     -0.7729;
            c =  -1.366e+05;
            fit = 2;
        real thrust = a * pow(U, b) + c;
        if (Uin < 5 || Uin > 25) // this should be based on the inflow velocit
                thrust = 0;
                fit = 0;
        *F = fit;
        *Thu = thrust;
        return;
 real find_U(int zone_ID)
        Thread *t = Lookup_Thread(Get_Domain(1),zone_ID);
        real  A[ND_ND], area, u, FU;
        //Setting up parameters for intergration calculations
        real Area = 0.;
        real Uint = 0.;
        //Parameters use in velocity calculation
        face_t f;
        cell_t c0, c1 = -1;
        Thread *t0, *t1 = NULL;
        //Loop finding the velocity in the at the face of the bounday
        begin_f_loop(f, t)
            c0 = F_C0(f,t);
            t0 = F_C0_THREAD(f,t);
            c1 = F_C1(f,t); /* Get cell on other side of face */
            t1 = F_C1_THREAD(f,t);
        //This loop would be used if using a boundary at a face (currently not working)
            //if (BOUNDARY_FACE_THREAD_P(t))
            //  FU = F_W(f,t);
            //else
                FU = (C_W(c1,t1) + C_W(c0,t0))/2;
            //Finding the intigral of the area and velocity over the face
            F_AREA(A, f, t);
            area = NV_MAG(A);
            Area += area;
            Uint += FU * area;
        end_f_loop(f,t)
        //Finding the absolute velocity from the itteration
        u = fabs(Uint)/Area;
        return u;
DEFINE_PROFILE(P_profile,t,i)
    //The velocity that the maximum thrust occours at
    real TmaxU = Get_Input_Parameter("real-1");
    real Uin = Get_Input_Parameter("real-2");
    real Fit, Thrust;
    real T = 0.;
    face_t f;
    int zone_ID = THREAD_ID(t);
        real U = find_U(zone_ID);
        //Finding the thrust from the rotor
        //real thrust =
        calc_Thrust(&Fit, &Thrust, Uin, TmaxU, U);
        Message("\n Iteration %i \n", N_ITER);
        Message("\n The velocity at the disk = %g [ms^-1] \n", U);
        Message("\n Thrust = %g [N] \n", Thrust);
        Message("\n The fit type is is %g \n If fit = 0 the rotor has cut out \n if fit = 1 the rotor is operating at prerated power \n if the fit = 2 the rotor is opperating at rated power \n", Fit);
        // Definging the nomalizer and fit for the variying thrust appliction
        real Normalizer =   M_PI*(U*1.900312055711436E+31-(U*U)*1.239282151015246E+30+(U*U*U)*1.527746910810211E+28+(U*U*U*U)*2.960019334514253E+26-2.963673545740138E+31)*7.618884895355087E-27;
            begin_f_loop(f,t)
                //Finding the position of the center of the face
                F_CENTROID(C,f,t);
                //Defining r
                real r = pow((pow(C[0], 2) + pow(C[1], 2)), 0.5);
                Message("\n r = %g \n", r);
                Message("\n x,y,z = %g, %g, %g \n", C[0], C[1], C[2]);
                real Fit = ( U*1.190921231278848E+1+r*3.406508852232519E-1+U*r*3.808625743577649E-1-U*(r*r)*5.733850224296987E-3-(U*U)*r*1.718198730826162E-2+U*(r*r*r)*2.282749620835556E-5+(U*U*U)*r*9.337225041318572E-5-(U*U)*6.514728979124498E-1+(U*U*U)*9.105092229400679E-3+(U*U*U*U)*2.840350168618951E-4-(r*r)*3.901239873300466E-2+(r*r*r)*9.475025722676119E-4-(r*r*r*r)*6.279363133413672E-6+(U*U)*(r*r)*1.217896337041497E-4-2.997824644171244E+1);
                F_PROFILE(f, t, i) = (thrust/ Normalizer)* Fit;
                //Calculating the thrust on the actuator disk
                F_AREA(A, f, t);
                real area = NV_MAG(A);
                Area += area;
                T += F_PROFILE(f, t, i) * area;
            end_f_loop(f,t)
 FILE *fp = NULL;
 char filename[20];
 sprintf(filename, "Output_%gms.txt", Uin);
 Message("%s ", filename);
  Message("%g ", Uin);
 //char filename[]="udfTEST_out.txt";
 fp = fopen(filename, "a");
  fprintf(fp, "Itteration %i [m^2]\n", N_ITER);
 fprintf(fp, "Area of the actuator disk = %g [m^2]\n", Area);
 fprintf(fp, "Absolute Area-Weighted Average Velocity Over the Disk %g [ms^-1]\n", U);
 fprintf(fp, "Value of the Normalizer = %g\n", Normalizer);
 fprintf(fp, "Total thrust fromt the disk = %g [N]\n", T);
 fprintf(fp, "Input thrust = %g [N]\n \n", thrust);
 fclose(fp);
