lilly santana
So which surface should I report it on instead? I'm trying to get the mass flow average temp of the fluid. When I plot temperature contours, the fluid temp appears to be constant and the same as the initial temp I patched it to. I'm not sure why, since I have multiple battery cells which generate around 7W (or 700 W/m^2) of heat to the fluid.
Thanks in advance!
