If you're manually adding energy into the system then you need to see if you're accounting for the phase change: I don't know what you're doing. The other consideration is if you're using compressible gas, and what's holding the gas in place: in a gun (of whatever size) the bullet/ball/shell holds the gas back as it's shot out of the barrel.
