Ya_Tang
Hi Rahul,
Thank you so much for your prompt reply. Yes, I export the System Coupling file via the Workbench. There are three folders generated, namely, “Fluent_2”,”Mechanical_1” and “SyC” (as shown in the following picture).
In the folder of “Mechanical_1”, there are “Mechanical.dat” and “Mechanical.scp” files exist. The problem is when I start to run the System Coupling, the “myCommands.dat” mentioned in the following picture does not generate.
The following is what I thought:
I am running a FSI modeling in a vessel. To make the simulation become stable, I choose to run the FSI in a higher materials property (Young’s Modulus) and restart with a low Young’s modulus after the simulation become stabled. In the new released version, I found that I can use additional Restart Input File (a modified myCommands.dat?) to replace the original auto-generate restart script (myCommands.dat) and use it for the restarted run. Is this right? Do you have any suggestions or advice for realizing this?
Thanks so much for your time,
Ya
