DrAmine
PATH_ABORT has the same effect as PATH_END and the particle is not tracked further.
I think you can use Trap BC, do sampling a long the wall to create a sample file which you might use to read the particles back for post-processing purposes. Though The TRAP BC does show the particle deposition distbriubtuon as Eulerian variable whenver you enable Acretion/Erosion rate calculation.
