You can use Named Selections in DM, those are usually (settings dependent) respected in Fluent Meshing. Or, in Fluent, open up the wall and change it's label. Note the label and ID are separate: the latter is a number generated within the case file and messing with that is a really bad idea. Note, changing the label may disrupt the Workbench workflow.
