julius.langenhorst
Thank you for your answer!
The picture in my original post should be the result of load vector 3. The way I structured my analysis is as follows (I probably didn't made that clear enough before):
  • Modal analysis and creation of three laod vectors
  • First MSUP analysis with subsequent post-processing using first load vector:
lvscale,1,1
lvscale,0,2
lvscale,0,3
  • Second MSUP analysis with subsequent post-processing using second load vector:
lvscale,0,1
lvscale,1,2
lvscale,0,3
  • Third MSUP analysis with subsequent post-processing using third load vector:
lvscale,0,1
lvscale,0,2
lvscale,1,3
Each MSUP analysis is started by issuing a new /solu command and closed with finish. This way all three load vectors should be used except, of course, they weren't created in the first place. But I used this evaluation scheme on other models and there was a response in x- and y-direction (both for MSUP and Full Harmonic).
