Ashish Khemka
Hi Saurabh,
Can you please check how the stress results are changing with contact surface change? What if you have finer mesh on both the contact and target side? What is the reason for using adjust to touch or offsetting the contact surface? What if you do not offset the contact? Please see if the following link is of use to you:
How to Designate the Contact | Ansys Innovation Courses
Ashish Khemka
